Would a EVGA Classified work with a EVGA SC 780 3gb?
iaOreo
I have a classifed and want to SLI it with a SC 780 from EVGA.
Specs - I7 4790K and two GTX 770s. Soon to be upgrading!
Both GTX780s? You should be fine, but you will have to OC the card to the OC clock speed of the other.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
Depends what classified card it is. If it's a 3GB 780 Classified, then yes, it will work as long as your board, PSU and CPU support SLI.
Cards work in sli as long as they are both based on the same gpu ( both 780's) , have the same amount of vram ( i assume both are 3gb) and are each running at pcie 8x
Linus did a video about it for more info.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
Cool, thanks guys. Will I be able to play at 1080p maxed out 4x msaa???
