Am I overloading a usb port with this USB hub (easy answer)
AnTicXz
http://www.amazon.com/gp/product/B00CBEVTIA?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A39OX00G2TFX52
I will attach
-keyboard
-mouse
-headphones
-High quality mic
-Webcam
-USB hard-drive for recording (Probably will use a dedicated port for this)
*Im afraid that I will cause a choke point with all of these deceives running at the same time.
*OR the mic quality will be bad because of the limited bandwidth
 Power is not a problem bc the hub has ac wall power
If your hub has ac power, there shouldn't be an issue.
EDIT: Last year with my 2010 MacBook, I used a 3-port USB 2 hub and that had my optical mouse and my 2TB external HDD connected, never missed a beat. However now due to lack of use I think it has probably died. It was just a cheap one that was powered by the USB itself.
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
It says it's 3.0, so I think you should be just fine, especially with it having its own power source. Out of that list the only real things I can see that would even strain it would of course be the hard drive, and the camera if you're recording in a large, HD resolution.
-This space intentionally left blank-
I want to step in here - you will NOT be fine for a mic + HD webcam + hard drive for recording.
You're not "overloading" it, but there isn't enough bandwidth for all that. Windows will even tell you such.
Likely the webcam won't want to open a lot, or it might stutter.
USB Hard drive speed will be severely limited and won't be remotely capable of recording.
"Epic Voice, Quality Content"
I've used a big USB 3.0 hub on a desktop with powerful USB 3.0 performance for over a year now. Originally hooked up mouse, keyboard, second mouse, webcam, audio interface, etc. and it couldn't handle the webcam half the time in Skype, and audio interface would reset a lot. (Keep in mind these are all USB 2.0, even, so less bandwidth usage.)
Moved the audio interface to a motherboard port, got rid of one connection, webcam still is finnicky.
You're definitely going to want the hard drive in a dedicated onboard port; probably the webcam, too.
Ok so my laptop has 2 Usb 3.0's and 1 2.0, How should I spread my devices out?
Get two USB 3.0 hubs with less ports each, rather than one giant hub.
Two of these would probably work well for you. http://www.amazon.com/AmazonBasics-Port-2-5A-power-adapter/dp/B00DQFGH80/ref=sr_1_6?s=pc&ie=UTF8&qid=1450317445&sr=1-6&keywords=4+port+usb+3.0+hub
"Rawr XD"
USB 2.0:
-keyboard
-mouse
-headphones (can't you use the audio jack instead of usb for that?)
USB 3.0
-High quality mic
-Webcam
USB 3.0:
-USB hard-drive
This would probably be "ideal"
CPU: AMD Ryzen 3700x / GPU: Asus Radeon RX 6750XT OC 12GB / RAM: Corsair Vengeance LPX 2x8GB DDR4-3200
MOBO: MSI B450m Gaming Plus / NVME: Corsair MP510 240GB / Case: TT Core v21 / PSU: Seasonic 750W / OS: Win 10 Pro
USB 2.0:
-keyboard
-mouse
USB 3.0
-High quality mic
-Webcam
USB 3.0:
-USB hard-drive
This, basically.
