Project - Dark Sunrise Panda
PandaCopyRight
This is my 1st computer build so i can learn a lot from this and if you guys and girls have any tips on what i should do or get you can say it ... i don't bite :)
Also since I'm just 17 and don't have a full time job it's kinda difficult for me to finish the build quickly but I'm trying what i can do.
My aim with this build is to make a build that can stream games (using Intel and Nvidia parts) with the color scheme of the motherboard mainly (btw my fav color is green so this will be fun :/), which was gifted to me for Christmas by my dad, and to make it near silent and the most important part ... have fun doing it and have fun with the computer.
The name of the build came from the color scheme and my favorite animal :)
Color scheme so far is Mostly red and black but adding some yellow and orange slowly
So this is my build so far:
>CPU: Intel Core i7 4790K (stock for now)
>Cooler: CoolerMaster Hyper 212 EVO
>GPU: Asus GTX 960 2GB Strix OC
>Case: NZXT S340 Red and Black version
>Motherboard: Asus Maximus VI Formula
>RAM: Kingston HyperX Fury 2xBlack and 2xRed (4x sticks of 4GB)16GB DDR3 @ 1866 Mhz CL10
>PSU: Corsair RM750x
>Storage: Kingston 120GB V300 SSD & Seagate 1TB 7200rpm
>Disk Drive: Cant fit one in this case
>Peripherals:
    Mouse: Razer Naga 2014 Cheapo mouse, my Naga died (what a surprise ... i know xD )
    Keybaord: CM Storm Octane (KB7C)
    Headset: Coarair Void Wireless
    Mousemat: SteelSeries Qck gaming edition with CS:GO graphics on it
    Monitors: (Main) Philips 239CL2SB (second and third) HP LP2065
    Wheel: Thrustmaster T150 Ferrari edition
    Pedals: Fanatec CSL LC
    Shifter: none currently
What I need to acquire:
RAM: Kingston HyperX Fury Red (2x sticks of 4GB)8GB DDR3 @ 1866 Mhz CL10
CPU: i7 4790K
GPU: Zotac GTX 1080 AMP! Extreme edition (ordered)
Cooling: Noctua NH-D15 (might go custom watercooling once i need to upgrade my cpu and motherboard)
Fans: 2x NF-A15 chromax for the cooler, about the rest most likely Corsair ML RED LED fans maybe some RGB fans if i feel like it
Cables: at some point custom red and black sleeved cables
LED: yes ... I will be having a RGB LED strip
Monitors: Planning to add a BenQ BL2420PT to my list of monitors
Keyboard: Corsair Strife RGB MX Brown NA layout
Mouse:  Logitech G903
Mousepad: Logitech PowerPlay
Microphone: Audio Techinca AT2020USB+ or Focusrite Scarlet 2i2 Studio pack
PSU: Corsair RM750i or HX750i
Shifter: Thrustmaster TH8A
Mobo - Asus Maximus VI Formula Ram - Kingston HyperX Fury 1866mhz CL10 16GBCPU - Intel i7 4790K ;
GPU - Gainward RTX 2070 Phantom ; PSU - Corsair RM750x Cooler - CM Hyper 212 EVO
too many red and black builds
btw what the hell is that psu?
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
How have you not heard of it, it's the bomb
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
lmao i see what you did there
if there are too many of them .. then maybe some tips on how to make it differ from the others?
idk .. dad bought it for an older pc that died of old age ... so i took it .. and seems to be perfect and its semi-modular and tbh i would like ot upgrade to a corsair RM850 .. but no need ... so far
idk .. dad bought it for an older pc that died of old age ... so i took it .. and seems to be perfect and its semi-modular and tbh i would like ot upgrade to a corsair RX850 .. but no need ... so far
first, upgrade the PSU, because thats the most vital part in your build, if it burns it will destroy every part in your PC with it, I recommend checking this tier list of PSU's
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
second to be different, just use different colors, something that you wont get bored of, I personally chose white, neon green and a UV LED strip, I don't see a lot of builds that are similar, also I have a very modable case, an Air 240, which I'll be modding to make it even more unique.
is my psu really that bad? i have not had any problems with it. also if i upgrade my psu ... i want the same or higher wattage (preferably a RM850 or RM850i) and i cant afford that
To me yeah its bad, because its not well known, also 650w should be more than enough for your build.
oke ill keep that in mind but for now i think im not gonna upgrade to a higher quality psu.
also would 650w be enough for a 2nd 960 in the future or something? yes i know the term futureproof is not a good term .. but i at least want to be able to add a 2nd card in case i need more gpu power and cant afford a better single card solution
  • 2 weeks later...
so ... i got the case put the pc in it and it looks like i spent hours on the cables ... even though i spent like an hour swaping the case xD
also ... my psu makes the pc louder than it is >_< so yeah .. i may or may not be getting a better psu soon
650W will be more than enough for 2 960s, you could SLI 980s with 650w
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
you could sli 980s with a 650w? :o
Yep, someone on the forums has a 980 SLI rig with 550W
oh.... well i still think im gonna be getting a 750w
