NH-C14S - I NEED PROFESIONAL HELP!
Hey guys, i have ran into a problem where the NH-C14S cpu cooler's end part is running into/touching my GPU.
The only way out that i see is to cut the end of the pipe by 3-5mm.
Will this in anyway ruin the heatsink?
Here is a picture of where i would like to cut it:
http://tinypic.com/r/30lcppj/9
https://linustechtips.com/topic/506796-nh-c14s-i-need-profesional-help/
That will destroy the heatsink as those heatpipes are hollow.
Your best option would be to get a pcie 16x riser
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
yes ti will ruin it
the heatpipes are hollow and have water in them
couldn't you rotate the cooler either 90 or 180 degrees?
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
This is THE most logical option.
Isn't it just a pipe?  is it hollow or solid?
if it's solid it would be perfect.
But i don't know.
It's hollow and contains something important of which idk the name but cutting it would ruin it.
USEFUL LINKS:
PSU Tier List F@H stats
Just in case you wanted someone else to tell you not to do it.  Don't do it.
Can you rotate the cooler at all so the heat pipes aren't in the way?  I don't know how the mounting solution for that cooler works.
CPU: Intel Core i9 9900K GPU: Gigabyte AORUS GTX 1080Ti 11GB RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Motherboard: Gigabyte Z390 AORUS MASTER PSU: EVGA SuperNOVA G3 850W 80+ Gold Storage: Samsung 970 Pro 512GB M.2 / Samsung 860 Evo 2TB 2.5" CPU Cooler: Corsair H150i Pro Case: Lian Li Lancool One
how about if you hammer it?
New: PCPartPicker part list
Old:Intel® Core2 Quad CPU Q8400 @ 2.66GHz, GIGABYTE GA-EP43T-UD3L, 4 GB Elixir PC3 ddr3-1333,  ASUS RADEON R7 260X, Thermaltake M9, 1TB HDD, GreatWall GW550SEL 550 WATT, BENQ GW2255, Hyper T4, Samson SR950 Headphones, fiio ek10.
But i don't know.
no there are gases and sometimes liquids in there that transfer the heat if you cut it you  will lose a ton of cooling.
But how do i connect my gpu to my case with a riser?
The slot for the gpu is located at one location.
what case are you using ? Mini itx ?
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
http://www.overclock.net/t/1438429/build-log-airborns-evga-hadron
(scroll near the end for finihed build pictures)
I wanted to make this EXACT build.
The problem i ran into is the fact that my motherboard (all z170 motherboard) pcie slot is closer to the cpu socket then the older mitx motherboards.  Hence the exact same cooler tocuhes the gpu.
If you rotate the cooler either 90 or 180 degree it should be fine, with intel sockets it can be tuned in any 4 direction.
How hard (/\/\/\/\/\/\) can that be?
USEFUL LINKS:
Just turn it
Guess so, it's going to ruin the whole look of it though because with the oreitntation done the some way as the link i provided it looked really nice as the whole window showed that it was coevered by metal.
Anyways, whatever.
Thanks everyone!
Any other ideas? shoot them my way.
