Need a motherboard for crossfire
Solved by Nyraion,
Then a B85-G41 board from MSI is your best bet. You loose the M.2 slot. http://www.amazon.com/MSI-Motherboard-Motherboards-B85-G41-MATE/dp/B00D12OASW/ref=sr_1_1?ie=UTF8&qid=1450284122&sr=8-1&keywords=MSI+B85-G41+PC+Mate+ATX+LGA1150+Motherboard
Bryan Lei ·
Posted in Storage Devices0 -
nate c ·
Posted in General Discussion1 -
ulookuglynoob ·
Posted in Peripherals0 -
23
2
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
