What graphics card should I get? HELP
A7XX
I have an old pc but I want to upgrade my graphics card
My current pc specs:
Intel core 2 quad q9300 2.5GHZ
RAM 4.00 gb ddr2
standard 500watt psu
intel dg33fb motherboard
current gpu: radeon 6850
I want to upgrade my gpu to either the new r9 380x or the 960 gtx
which one?
Surely, you don't mean one of these:
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 1TB Crucial P5 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 10 Pro x64
It will die. Your CPU will likely bottleneck, and your PSU isn't high enough quality.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
yea one of those am afraid, technology in our country is very expensive you guys have no idea..I was thinking the 960 is the better choice for me till i can afford a new rig
I would ask what do u recommend for me to upgrade, but a massuming you're gonna say the whole friggin thing :D
well... would you rather pay for an expensive power supply
or have your new gpu catch fire because of a dodgy power supply?
I would ask what do u recommend for me to upgrade, but I'm assuming you're gonna say the whole friggin thing :D
LGA 775 is a bit of a dead end. What country are you in? If your in the UK, get a new motherboard online, see if you can get a good deal on a CPU from somewhere like CEX. Otherwise, use PCPartPicker. (In fact, use PCPartPicker anyway, no matter what)
Main Gaming Rig:
Secondary PC:
why?
500W is enough for 390
Low quality OEM PSU
Main Gaming Rig:
Secondary PC:
Does that PSU even come with PCI-E connectors??? Please don't do molex to PCI-E adaptors... Probably that PSU is saying 500W is its "peak" wattage which I don't think it will last 10 seconds on that wattage. I would suggest a 750 Ti with no additional power input.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
Or the whole rig, GPU or PSU catching fire is more likely though.
EDIT: I mean the rig catching fire...
Main Gaming Rig:
Secondary PC:
eh. maybe drop in 4 gigs extra ram, other than that its *fine*
 get a better psu first
We're all dying slowly
Pentium G3258 3.2 ghz / ECS z97 pk MOBO / Intel Stock Cooler / R9 290 DD / Corsair Carbide Air 240 / 4GB mushkin stealth ram at 1600 / XFX 650W 80+ gold PSU / Kingston v300 240GB drive W/300GB seagate drive / HP x2301 / Gateway KB / Monoprice GM
why?
with that psu its generic as fuck and might have reliability issues with higher voltages
also, no it is not
This is also route you can take. You don't need to spend a ton on your PSU. :) The lowest priced models from XFX or Seasonic are EXCELLENT!
Echelon Mk 2.11
also, no it is not
i was talking about the wattage not the actual PSU
and YES, 500W is enough
oh man, thank you guys for the advice, I'll figure something out then!! Thanks a bunch
