Does a 8m HDMI cable cause any delay to the output display?
Strayan_Hades
Go to solution Solved by Glenwing,
Hi,
I've been thinking to hock up a hdmi cable from my study to my living about 8 meters away that outputs my computers display for Movies and Games like a home theatre PC.
But will there be any major delays or other complications?
Cheers.
No, cable length doesn't affect latency.
Hi,
Cheers.
Hi,
Cheers.
8 meters divided by the speed of light is 26 nanoseconds if that's of any significance to you. it's about a 15 millionth of a frame
Time to upgrade 2 diamond cable for $999999999999999999999999999999999999999999
Ryzen 5 1600 - GTX 980 Ti - Broke.
Lol.
big time, I'd consider upgrading to diamond braided cable
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
