LoL Build for Friend.
DiegoWithLag
Go to solution Solved by Fulgrim,
CPU: AMD A10-7870K 3.9GHz Quad-Core Processor  ($128.95 @ Amazon)
Motherboard: Gigabyte GA-F2A88XM-HD3 Micro ATX FM2+ Motherboard  ($64.88 @ OutletPC)
Memory: Kingston Savage 8GB (1 x 8GB) DDR3-2400 Memory  ($52.99 @ Amazon)
Total: $281.81
Generated by PCPartPicker 2015-12-14 00:56 EST-0500
Hey, so my friend plays LoL and wants to start a team with his friends and playing more demanding games, but he has a cheapo Win 7 PC with a Pentium and Intel HD. He struggles to play at 60fps on fullscreen, taking for account that he has a 900x1024 monitor (not sure of the resolution but its 19 inches long) with some crappy Keyboard and Mouse.
I proposed to him that he should build a new PC and he agreed, but he will have an extremely tight budget.
So i wanted to see if a new Mobo, CPU, RAM, and GPU would fit on a budget under $300 USD. (Taking on account that we would reuse the case and HDD) However... Im not sure if he can stick with his old PSU or if a new one would be needed.
Any reccomendations?
Thanks
Diego
Total: $281.81
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
http://pcpartpicker.com/p/wLpN8d FX 6300, 1x8GB 1600, 500B, GTX 750 TI, MSI mobo $320
http://pcpartpicker.com/p/L62TGX FX 6300, 1x8GB 1600, 500b, GTX 950, MSI mobo $320
http://pcpartpicker.com/p/xsvmXL AMD A10 6800k, 2x4gb 1600 , 500B, Gigabyte mobo $227 after rebates $255 or so before.
que?
i5 4590 @ Stock, XFX R9 290!, HyperX Beast 4x8GB  @1600, 850 EVO 120gb, WD Caviar Blue 1TB, , Asrock H97m Pro 4 , Fractal Design Define R4, Windows 10
Seeing as how League will pretty much run on a casio calculator watch, I'd suggest getting an APU. It will be fine for 1080p as long as he doesn't care if everything is on Ultra.
go used.
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
What does he have now?
I find it very hard to believe it can't run 60fps on a panel of that quality.
@DiegoWithLag follow your posts :rolleyes:
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
League isn't that easy to run, My laptop with i5-5200u 8GB of ram struggles on Medium at 1368x768. If he has a Pentium pc it's most likely one of the way older ones that came with those Acer Windows Vista pcs *just an example since I had one*
i3, H81 Motherboard, Q6600, LGA775 Motherboard, 8GB's of RAM, GTX 950, and a EVGA 50
he has 4g of ram and a dusty pentium g620 from 2008
I suppose. Even the recommended system requirements are only a 3ghz, 4GB of RAM, 8800GT machine though.
Really? Odd. My ultrabook ran it just fine, with a higher resolution.
Yeah, I don't know if something's wrong with my processor what, definitely doesn't perform how benchmarks online show though.
I'd do this.
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($72.98 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($19.89 @ OutletPC)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  ($47.98 @ Newegg)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1866 Memory  ($34.99 @ Newegg)
Video Card: Asus GeForce GTX 950 2GB Video Card  ($139.99 @ SuperBiiz)
Total: $302.83
Hmm if I were him I would just have him get a high end APU and perhaps use the left over money for a higher end motherboard and 2400Mhz ram.
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor ($63.56 @ Amazon)
Motherboard: Gigabyte GA-F2A68HM-H Micro ATX FM2+ Motherboard ($41.98 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($34.99 @ Newegg)
Video Card: XFX Radeon R7 370 2GB Core Edition Video Card ($99.99 @ NCIX US)
Power Supply: EVGA 400W ATX Power Supply ($25.98 @ Newegg)
Total: $266.50
Generated by PCPartPicker 2015-12-14 00:44 EST-0500
If you want you could step up to a r9 380 and be slightly over $300.
I wouldn't. No upgrade path. At least if he wants to take the graphics card onto another system with this he can, plus it's a lot more powerful.
I wouldn't really call transferring a GTX 950 into another system an upgrade path, where as RAM is used in all computers and having a max of 2400MHZ will be useful in any build
...unless he buys any newer Intel or AMD chip, which uses DDR4.
The video card is PCI-e and can be used with anything ;)
RAM is also cheap.
Higher MHZ RAM generally does nothing, except when used in conjunction with an APU.
