Remove heat spreader or cut plastic?
I just bought a dark rock pro 3 to replace my hyper evo 212 and just want to see what would be a better option for me in the case that the cooler collides with my RAM (I'm fairly sure it will, I have 2 sticks of GSkill sniper RAM). Now cutting down the plastic is no problem, I found an image of the internals of the RAM so I can be sure not to cut into the PCB. But would removing the heat spreader entirely be a bad idea? Could my RAM potentially overheat to the point of failure if I do this?
RAM is so power efficient these days that the only reason consumer memory has heatspreaders is for looks. Server stuff is where you will actually NEED the heatspreaders because a lot of those systems are completely passively cooled and also a lot of that memory is used at full bandwidth for extended periods of time.
I removed the heat spreaders on my old ram. They really do not need them unless you are doing very intense tasks without a whole lot of airflow.
The most intensive thing I'll ever be doing is gaming. Maybe a little folding here and there but nothing more. I'll be fine?
@LinusTech should do a temp test with and without heat spreaders if that's possible :o
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
Ya. I did CAD work on my old G.skill Ripjaws. I wanted black RAM, the heat spreaders were red. The PCB was black. Ask @CalebTheEternal, they still work :P
Still work, as far as I know, it's just sitting in my basement :/
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
