I have a desktop that i built 5 years ago that i would like to upgrade for better gaming performance. I need some help figuring out if it is really worth it putting any money into this system and if so, what should i be spending my money on. I'm looking to spend no more than 500 USD.
Here is my current system:
Corsair VX 550W PSU
ATX 12V V2.2, 80 Plus, Standard, 1x 6pin, 1x 6+2-p
Intel Core? i5 Dual Processor i5-660
Dual Core, 3.33Ghz, Socket 1156, 4MB, 73W,
ASUS P7P55D, P55, Socket-1156
DDR3, ATX, GbLAN, Firewire, eSATA, PCI-Ex(2.0)x16
ASUS GeForce GTS 450 1GB PhysX CUDA
PCI-Express 2.0, "DirectCU", GDDR5, 1xDVI
Corsair XMS3 DDR3 1600MHz 4GB CL9
Kit w/2x 2GB XMS3 modules, CL9-9-9-24, for Core i5
The links are to a Norwegian site, sorry.
https://linustechtips.com/topic/505032-help-uprgading-5yr-old-desktop/
Get an SSD and a 380 GPU, you should be all set
Buy SSD, replace graphics card
Guys, you've missed that the i5 is a dual core which is going to bottleneck most titles. You should look at quad core second hand i5s on eBay or AMD chipsets.
I'd recommend a cheap i5 quad core & MB combo, 8GB of RAM (upgrade later to 16), and a new GPU... Something like a 380/370 or 970/960. Grab an SSD if you can afford it too. Anything over 60GB for your OS would be fine.
Being that your budget is $500, possibly picking up some 2nd hand cards like the 280X, or 290 could work in your favor too.
It's got hyper threaded, it would be fine overall, a GPU is going to be more important than a new CPU, though an 860K isn't very expensive in most places
His CPU is literally on par with a 860k.
So not much reason to replace it with a 500 dollar budget then, although I'm sure the 860k is at least a little bit faster
Honestly? I'd sell the current rig and use the money towards something better.
Figure you can get about $225 USD for it.
You could build something like this:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($19.89 @ OutletPC)
Motherboard: Gigabyte GA-B85M-GAMING 3 Micro ATX LGA1150 Motherboard  ($59.88 @ OutletPC)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1866 Memory  ($34.99 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive  ($74.99 @ Amazon)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($293.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($36.99 @ SuperBiiz)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($45.98 @ Newegg)
Total: $741.69
Naturally your local market will likely have different retail pricing, but your used market will also be different so you might end up getting more for your old rig.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
No the 860K is 7% slower.
Well where are you getting that?
Userbench
It seems relatively even overall, the breakdown puts them within 2% of each other, not sure if he can overclock his CPU well with his current set up though
Look at the power delivery on that motherboard, it has 12+2 phase power delivery that thing would rock it like a boss, I would recommend he spends 60$ on a quad core 1156 CPU on eBay, then buy a hyper 212 and then attempt to BCLK overclock it to around 3.5-4.0ghz, that would solve his CPU problems for just under 100$.
Then upgrade to 8gb of ram for about 40$.
Get better PSU for about 60$.
Buy a 390 with money left over.
