First Build for 1080p
PalkiaRock484
Hi! I am building my first PC for 1080p gaming at 30-60 fps. I don't care that much about settings as long as they're decent. Tell me if anything sucks or if there is something better for the money. Thanks!
http://pcpartpicker.com/p/HBQL8d
Grump Bumb
You can get a slightly cheaper psu that's just as good: http://pcpartpicker.com/part/xfx-power-supply-p1750gts3x
Other than that, you're good.
Personally I would maybe swap out the 16gb for 8gb and then upgrade R9 380 to R9 380x.
Build: i5-4460 | GT 720 | Logitech G710+ Keyboard | Corsair M65 Mouse | Dell e2314h Monitor | Windows 10
Generic Dell: Mobo, 8gb RAM, 430w PSU, 1TB Storage, XPS 8700 Case
Read my mind. Or a used 290 but those might be risky.
Sig under construction.
disregard
if you can, go for standard atx for the love of god
why standard atx?
Grump Bumb
standard atx?
everything youve got is micro atx
itll work, but leave basically no room for upgradeability
I'll consider it, but I don't see myself doing anything crazy with it.
Anything in particular I could upgrade with standard atx that would be worth the money?
Grump Bumb
being able to have any expansion cards other than just your video card
What brand do you recommend for a 380x?
Grump Bumb
Micro ATX supports two-way graphics and quad-channel RAM. Why would you need anything larger unless you were doing quad graphics (which you shouldn't) or had piles of PCIE devices, which I doubt the OP has? MATX is plenty upgradable for almost everyone.
Other systems I've built:
sonofabitch i was thinking of itx...
either way, sometimes you want a network card
What brand do you recommend?
GPU brand? ASUS Strix: http://www.newegg.ca/Product/Product.aspx?Item=N82E16814126048&cm_re=380x-_-14-126-048-_-Product
RAM brand? Anything that isn't super shady (Kingston, Corsair, G.Skill, etc.)
I don't think I'll need anything more than the onboard ethernet but thanks though!
Grump Bumb
Would any of you recommend going for a 212 evo or would the stock cooler be good enough.
(I'm not oc in any way shape or form)
Grump Bumb
You could buy a better motherboard like the MSi H97 gaming 3 for some oc in your card
