R9 390 and 4790k with a 550w psu
Solved by i_build_nanosuits,
and if i want to over clock?
you have plenty of headroom my machine from the wall pull 400W maximum under full CPU and GPU load running synthetic benchmarks (very unrealistic load) so at 90% efficiency that mean the parts only need around 360W of clean power...and i think the 980ti is even a bit more power hungry than the R9 390 (might be wrong, i think they are pretty similar...in power consumption i mean not in performance)
