Air cooled CPU & Water cooled GPU's in same system?
I'm thinking about getting better cooling on my 2x GTX 980TIs because of how much heat they produce 81c (I know that is what there supposed to run at but I still don't like it.) I'm thinking about getting two hybrid kits for the GPUs that are in SLI. Is it practical to cool the CPU with air and my two GPUs with AIO (All In One) coolers?
Just push the air from the cards out and its fine.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
It'd be fine!  If you make your GPU radiators exhaust it should work fine.
