Gsync Monitor Feature hard to calibrate
Hi,
Just been playing around with my monitors colour and contrast but unfortunately in the G-Sync mode I'm limited to only a few options Brightness, Contrast, Low Blue light, Black eQualizer and AMA.
I'm using the Benq xl2420g and love G-sync but I just can't calibrate it right and yes I know its a TN panel. So any suggestions on the best calibration settings for this monitor?
If the OSD options are not available, have you tried using the inbuilt color calibrator in windows?
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
Where can I locate that? in nvidia control panel?
Now that you mention it, I believe the nvidia control panel also has color calibration tools.
http://prntscr.com/9dg63m
