Choosing right DVI to display adapter
Hi everyone
I have to buy DVI to display adapter because on my graphic card i have only DVI out.
Is there anything particularly that i should take in consideration when buying this adapter. length of cable ...
I will be using it for my Dell U2515H
Thank you all.
Hi everyone
Thank you all.
DVI to HDMI is your best bet. Both are the same technology.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
The Dell U2515H takes DisplayPort and HDMI inputs.
So in this case you'll simply need a DVI-D or DVI-I to Displayport or HDMI adapter.
A DVI-I to Displayport adapter looks something like this:
DVI, DisplayPort, and HDMI are all digital. With DVI to DisplayPort, you just need an adapter just like with DVI to HDMI. Converters are not necessary.
Edit: In order to use a DVI to Displayport adapter, it needs to be active.
Edited by Godlygamer23
The pins in HDMI connectors and DVI-D connectors are all the same. Displayport isn't the same.
Stille (Desktop)
Evoo Gaming 15"
I need "male" DVI to  DVI . My question is should i avoid long cable ?!
The cable length is for the most part is a non-issue.
  • 2 weeks later...
DVI does not adapt to DisplayPort. Those cables only work from DisplayPort on your GPU to DVI on your display.
Eleven days after i placed order and few days before my shipment arrives i see this post. I guess i will have opportunity to prove to myself that i made wrong choice while shopping.
Next stop DVI to HDMI adapter.
 Right !
