HELP! Ultra power saver on Lumia cannot exit from Lock screen!
AlTech
Go to solution Solved by AlTech,
Fixed it! it turned out it was the narrator and so I had to tap the lock screen, then double tap it.
1. Input password by tapping to select and double tap to enter it (make sure to reduce volume as it will giveaway your password)
2. tap on search button and then double tap it.
3. tap on microphone button and then double tap it.
4. Say "Go to settings"
5. then once cortana reaches settings tap on search and then double tap
6. tap on e and then double tap on it.
7. Tap on ease of use as it should appear then double tap
8.then tap on narrator and double tap and boom it will be back to normal.
Help! I can't unlock my phone from Ultra Power Saver thingy in WP8.1 .
Running Wp8.1 GDR2 (8.1.2 with Lumia Denim).
How can i regain access?
Currently the CPU is too slow to access the lock screen or do anything. All i can do is tap on something and boom it highlights it lke 5 seconds later.
HELP! If i try to run this out of battery i can't realy since it's such a large battery (3000mAh) and it's almost full (80%).
I didn't mean to trigger it but it was triggered anyways.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
It's been happening to my Lumia as well. I literally put it in the freezer for 1 minute cause it overheats easily (planning to switch to Android). Then I restart it, and it's all fine. till the next time it happens again.
same is happening here
lol mine never overheats xD
Ahaha, marks his own post Best Answer, Nice!
Well, to be fair,  i found the solution to fix it
