May and Will -ENGLISH QUESTION
Xenift
Guys i stumbled upon a person trying to correct me.
For example, this cheesecake may and will be salty.
Is this correct? I said it was contextually not appropriate.
It sounds stupid but yea... i think its grammatically correct.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
Just going off of this sentence alone, no. By using both "may" and "will" you are contradicting yourself. "May" is a subjective verb because it implies that the level of salty-ness is dependent on the tastes of the person eating the cheesecake. "Will" is declarative verb because it expresses that, no matter what your tastes are or how you define salty, it is salty.
If we had more context it might change the meaning a little, but I am having a hard time thinking of a situation when may and will can both be used when referring to the same subject in a single sentence.
Edit: After thinking about it, no, it is not grammatically correct and cannot be correct no matter what the situation because the verbs will always contradict each other when referring to the same subject.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
Well thank you. I feel like less of an idiot now. xD
A 14 yr old corrected me :D
Makes no sense. "May" implies that it might be salty and then you say that it will be salty. Wat?
Other systems I've built:
I don't think it's that bad. People regularly say "if and when x happens" which doesn't technically make sense, because you're stating it will, so why bother using the if? It's just a phrase. I wouldn't sweat it really, people who feel the need to correct grammar that's perfectly understandable in a context that doesn't require grammatical accuracy are just annoying.
i7-7700 | Asrock H270M-ITX | Fractal Design Core 500 | 16GB Corsair Vengeance LPX | EVGA GTX 1080 Ti | 850 EVO 500GB | 850 EVO 250GB | WD CavGreen 2TB
EVGA SuperNOVA 550W | Steel Series Elite Prism | Final mouse 2015 | WASD Keyboards V2 (MX Blue) | Acer Predator 1440p 144Hz
