Recommended Power Supplies
Hei I want you to answer my question guys
My PC Spec are here:
AMD FX 4100
RAM Dual Channel DDR3 with 8GB
ASROCK Motherboard
HDD 750GB with WD brand 7200RPM
ASUS HD 7750 1GB GDDR5
yesterday, my power supplies are explode , XIGMATEK TAURO 550WATT
and I Want you to give me some suggestion, which one I must buy Right PSU as cheap and good quality and also durable,
Please give Me your answer . :)
thanks . And Sorry for my bad English
I'd say get a good quality 550w that will last you even to your next build.
EVGA G2, the new Corsair RMx line, or any XFX PSU i'd recommend.
"If you ain't first, you're last"
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
does corsair VS series good ?
my PSU exploed because electry tension is not stable
would you suggest me what UPS brand should I buy?
thanks
thanks
Corsair VS is just a CX-M so not really. It's also not a UPS, If you want a UPS make a new thread. I assume you want a PSU. Check out the "PSU whitelist" in my signature below for lots of options.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
