About 'Samsung 950 PRO 256GB M.2 NVMe'
Micael
It overheats when being used a lot
but if you're not using it a lot then you're not getting your money's worth...
but if you have lots of $ then that shouldnt be a big problem
Is your system worth it? Easily though I would not spend that kind of money on a SSD. I think a 500GB 850Evo Sata would be much better, personally Storage > A bit faster of a SSD though it is all up to you.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
I'm not sure if it will work on that board, is there any UEFI options in the bios? It doesnt appear to have a m.2 port, which isnt a problem as there are existing PCIE adapter cards
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
On the storage section of my motherboard specifications, it says:
Intel® Z87 chipset :
1 x M.2 (NGFF) Socket 2 on mPCIe Combo II expansion card(s), black
Support M.2 (NGFF) Type 2242 SSD card (22mm x 42mm), Support PCI express 2.0 x1 and SATA 6Gb/s standards
Ye the Samsung wont fit, its a 2280 type card.
Basically your card accepts a 22mm wide ssd and 42mm long. The Samsung is 22mm x 80 mm
Ryzen Ram Guide
So I'll need to buy and PCI Adapter?
Ryzen Ram Guide
