VRM Cooling VS North Bridge Cooling
TubsAlwaysWins
Should I position my stock heat sync fan over my VRM heatsink or my north bridge heatsink? I will be overclocking to Kingdom come so that's why I'm wondering
Breaking things 1 day at a time
Maybe a fan over the VRM heatsink, those get quite toasty when overclocking an AMD FX-8300 series CPU.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
Ok. Should I put it in push or pull? Or does it make a difference
Push would be better. So the fan will blow air on top of the VRM heatsink.
How do you recommend mounting it?
Well how I did it was I simply rested a fan on top of my GPU and faced it towards the VRM heatsink. Not pretty but it works
I'll try zip tying it to my waterblock first
