What Be quiet should include with their coolers.
ashypanda
after scraping my knuckles with the little spanner they include with their mounting hardware, this is what i use to tighten the cooler.
7mm socket, a 1/4" extension, and a hex to 1/4" extension to a 1/4" to hex adaptor, and a 1/4" drive ratchet.
post-31389-0-43044500-1449767801_thumb.j
Intel i5-6600K@4.2GHz, 16GB Crucial DDR4-2133, Gigabyte Z170X-UD3, Be quiet shadow rock slim, Sapphire RX 480 Nitro+ OC, Fractal design Integra M 550W, NZXT S340, Sandisk X110 128GB, WD black 750GB, Seagate momentus 160GB, HGST 160GB
or you could mount your cooler on your mobo outside the case
like normal people
like normal people
well if you just got a new cooler to replace then it will be way more hassle to get the motherboard out. all those connectors sata gpu wifi card and so on
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
i still scrape my knuckles outside the case, as my motherboard as a plastic shroud over the IO, which limits space.
rip that shit out xD
Builds:
honestly i would but it matches my S340 so well.
well then that sucks. i really dont give the slightest shit about aesthetics if i would i probably would have a case side and i probably wouldent have a fan cooling my wifi card just sitting on my graphics card xD.
Builds:
