I am looking for new water cooling coloring.
I want to see through the loop, Sort of like vitamin water, but darker. I don't really like the pastels. Does anyone know a good dye.
mayhem
Mayhems has a X1 series of fluid which is clear and you can also get dyes for custom colorings.
I am looking for dyes becasue I already have PrimoChill clear fluid
mayhem
where do I buy mayhem, I looked on their store and I only found it in pounds, not USD
Where are you located, if your in the USA Performance PC's should have all you need.
Yes that's a good option, EKWB fluids are a partnership with Mayhems.
Okay thanks for the help :)
