I need help choosing a PSU!
Bombfish
I have a long wait behind me, I mean a looong wait. I have been waiting to get enough money to my first build for ages. The time is finally here and I dont know which PSU I'm going to buy D:
My current plan is:
Case: Phanteks enthoo Mini XL
Mobo: asus VIII gene mATX
CPU: i5 6600k
GPU: Sapphire R9 390 (with backplate)
HDD: 1000gb WD Blue
RAM: 2x4gb HyperX ddr4
My plans are that I will buy a second GPU later and I really dont want to change my PSU aswell... :/
I also would like to hear your comments on the plan and is r9 390 CFX better than GTX970 SLI.
Thanks in advance!:)
if you want a second r9 390 later down the road, the CM V1000 should be sufficient with headroom for a overclock and future upgrades
and r9 390 all the way vs the gtx 970
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
Antec High Current Gamer 850W or EVGA G2/GS 850W is more than enough for 390CF
My current plan is:
CPU: i5 6600k
HDD: 1000gb WD Blue
Thanks in advance! :)
but before you think of a second r9 390 does the mobo support crossfire and or sli?
nvm it supports sli
but before you think of a second r9 390 does the mobo support crossfire or sli?
It does as long as the cards are 2 slots thick :D
And the PSU also needs proper connectors for dual GPU, becouse the sapphire cards use 2x8pin connectors
My current plan is:
CPU: i5 6600k
HDD: 1000gb WD Blue
390CF = better than 970 SLI = 980ti still recommended. For two cards (two 390s) 750-850W is recommended. For the dual 970s 650W is recommended as for a 980ti.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
