Build problem: Broken USB Front Panel Connection on Motherboard
Solved by 404-USER-NOT-FOUND-ERROR,
Thank you so much for that! I've actually run into another problem...the system won't turn on. The "Start/Stop" button on my Corsair 380t is lighting up when I flick the On switch of the power supply, but when I press that "Start/Stop" button, nothing happens. If I can't figure that out soon, I'll likely make another post here on LTT.
sorry for replaying late, I think you may have got a defected motherboard, I would recommend you to refund the motherboard or make another topic on the LTT
