Posted November 30, 2015 Hey guys! So, I just bought a new PC, which was assembled for me by the shop. And, now that I've started using it, I've got quite a few problems. First, though, here are the specs: OS: Windows 10 64-bit CPU: Intel Core i5-6600K CPU Cooler: Xigmatek Colosseum Motherboard: Asus Z170 Gaming Pro RAM: 2x 8GB Kingston Hyper-X Fury 2600 SSD: Samsung 850 Evo 250GB HDD: WD Blue 1TB PSU: Season M12II Bronze 750W Monitor: Acer Predator X34 The issues: 1. I randomly have 'thump' or 'pop' sounds coming from my monitor speakers. Also, when playing something, the audio often stops and it's a stop-start sequence, where the audio plays for 10-20 seconds then stops for a while then starts and so on. At first, I was chalking this up to the monitor, because the Predator X34 has had quality control issues but I'm not so sure now. This is also not a persistent problem. Sometimes, I can have a whole session without any problems and at other times, not so much. The computer going to sleep/restarting/shutting down seems to be the trigger but, then again, when that happens, the monitor also goes to sleep/turns off so maybe that's the trigger. 2. At times, Windows will randomly just go crazy and the taskbar will be visible but the right side of it (where you have the time/date/wifi/speakers and so on) just disappears. After this, the system is just crazy. I can open some apps but not others. Most of the normal stuff you can do on Windows just stops working. And, this isn't something that has happened only once but multiple times now. 3. At other times, the whole screen just goes blank and all I can see is the cursor. This usually happens after I restart the computer/power it on but has also happened after everything seeed to be working perfectly and I was on the lock screen but it suddenly blinked and bam! The screen went dark, with only the cursor. NOTE: Ok, so, when the PC came, it didn't have Windows so I installed it myself but, after it started and I left for a while to let it do its thing, and then returned a little while later, there was just a black screen. I let it remain like that for, I don't know, 30 minutes before doing a hard reset. Then, when I tried to boot using the SSD, it wouldn't work. I tried booting using the USB drive through while I was installing the thing and it didn't work either. Then, I chose a bunch of the options and it just did and booted me into Windows 8. I then upgraded to 10. Anyways, I first thought that some problem during this time was leading to my issues so I reset Windows and it's still the same but I thought I should explain it, in case it has some relevance. I'm a total newbie to DIY builds (which is why I let the shop assemble it for me) so I'm wondering what I should do. Any help would be appreciated. On the audio front, I was first thinking it was something to do with the monitor but now I'm not so sure since I've read about the Z170 Gaming Pro having other audio issues. It's not the same as mine but, well, it does make me wonder. Before you say install the latest drivers, I've already gone to Asus's website and done so. Also, resetting Windows obviously didn't solve 2 and 3 so I'm not sure exactly what's going on. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 30, 2015 For all of this: do you have drivers? Check your equipment manufacturer's website for drivers. Secondly: is everything installed correctly? If you have a removable and replaceable amp on your motherboard, is it plugged in properly? Is your video card plugged in and powered using all necessary PCIe auxiliary power? "Not breaking it or making it worse is key." "Bad choices make good stories." Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 30, 2015 Hey guys! So, I just bought a new PC, which was assembled for me by the shop. And, now that I've started using it, I've got quite a few problems. First, though, here are the specs: OS: Windows 10 64-bit CPU: Intel Core i5-6600K CPU Cooler: Xigmatek Colosseum Motherboard: Asus Z170 Gaming Pro RAM: 2x 8GB Kingston Hyper-X Fury 2600 SSD: Samsung 850 Evo 250GB HDD: WD Blue 1TB PSU: Season M12II Bronze 750W Monitor: Acer Predator X34 The issues: 1. I randomly have 'thump' or 'pop' sounds coming from my monitor speakers. Also, when playing something, the audio often stops and it's a stop-start sequence, where the audio plays for 10-20 seconds then stops for a while then starts and so on. At first, I was chalking this up to the monitor, because the Predator X34 has had quality control issues but I'm not so sure now. This is also not a persistent problem. Sometimes, I can have a whole session without any problems and at other times, not so much. The computer going to sleep/restarting/shutting down seems to be the trigger but, then again, when that happens, the monitor also goes to sleep/turns off so maybe that's the trigger. 2. At times, Windows will randomly just go crazy and the taskbar will be visible but the right side of it (where you have the time/date/wifi/speakers and so on) just disappears. After this, the system is just crazy. I can open some apps but not others. Most of the normal stuff you can do on Windows just stops working. And, this isn't something that has happened only once but multiple times now. 3. At other times, the whole screen just goes blank and all I can see is the cursor. This usually happens after I restart the computer/power it on but has also happened after everything seeed to be working perfectly and I was on the lock screen but it suddenly blinked and bam! The screen went dark, with only the cursor. NOTE: Ok, so, when the PC came, it didn't have Windows so I installed it myself but, after it started and I left for a while to let it do its thing, and then returned a little while later, there was just a black screen. I let it remain like that for, I don't know, 30 minutes before doing a hard reset. Then, when I tried to boot using the SSD, it wouldn't work. I tried booting using the USB drive through while I was installing the thing and it didn't work either. Then, I chose a bunch of the options and it just did and booted me into Windows 8. I then upgraded to 10. Anyways, I first thought that some problem during this time was leading to my issues so I reset Windows and it's still the same but I thought I should explain it, in case it has some relevance. I'm a total newbie to DIY builds (which is why I let the shop assemble it for me) so I'm wondering what I should do. Any help would be appreciated. On the audio front, I was first thinking it was something to do with the monitor but now I'm not so sure since I've read about the Z170 Gaming Pro having other audio issues. It's not the same as mine but, well, it does make me wonder. Before you say install the latest drivers, I've already gone to Asus's website and done so. Also, resetting Windows obviously didn't solve 2 and 3 so I'm not sure exactly what's going on. What i would do, because you're having so many issues, just backup your files, and do a re install of windows.... should fix everything.... CPU: Ryzen 7 5800x + H150i Elite LCD RAM: 32GB Corsair Vengeance Pro RGB DDR4 3600MHz CL16 Motherboard: Gigabyte X570 Aorus Pro GPU: MSI RTX 3070 Ventus 3X OC SSD 1: Corsair MP600 1tb (Windows) SSD 2: Samsung 840 EVO 120gb (Scratch Drive) SSD 3: Samsung 860 EVO 250gb HDD 1: WD Blue 1TB HDD 2: Seagate Barracuda 2TB Case: NZXT H710 PSU: Corsair TX750M Mouse: Lamzu Atlantis Pro Mini 4khz Keyboard: Akko 5075B Plus OS: Windows 10 Pro 64-bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 30, 2015 Try resetting the bios Reinstall windows from scratch(it might help, highly doubt it) Rig: Thermaltake Urban S71 | MSI Z77 G45-Gaming | Intel Core i5 3570K (4.4Ghz @ 1.4v) | CM Hyper 212 EVO | Kingston HyperX Fury 8GB | MSI GTX 660 | Kingston 120GB SSD | Seagate 3TB HDD | EVGA 850W B2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 30, 2015 Did you install drivers? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 30, 2015 Doesn't the shop provide some customers services also a question you have Acer Predator X34 and you are using built in graphics. Wow Magical Pineapples
