Help saving my PC it got wet
Solved by Skyfire,
I'd dry what you can and leave it off for a while (48+ hours or so to be safe). Dry the components gently with a hairdryer or something similar. It's going to take a while for trapped water to evaporate so try to be patient. You don't want to short anything.
TPhill110 ·
Posted in CPUs, Motherboards, and Memory1 -
Mozametweakin ·
Fat Cat11997 ·
8
cbrngrz ·
Posted in Home Theater Equipment2 -
Brass5226 ·
Posted in LTTStore.com Merch1 -
1
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
