Search In
  • More options...
Find results that contain...
Find results in...
How to lower pc noise
My pc makes a sh*t ton of noise when I boot up any graphic intensive game. I have a small hp pc that I upgraded and most notably after putting my new graphics card I started to hear a huge difference. It's the xfx r7 260x 1GB and it's a very small card. I also have a very small case. Is there anything I can do to lower the sound level besides cranking up my headphones? I like to play gta 5 with friends on it aswell... pls help almighty LTT-forum gods!
Thanks in advance,
That13thGuy
01110101 01101100 01100100 00100000 01100100 01101111 00100000 01110011 01110101 01100011 01101000 00100000 01100001 00100000 01110100 01101000 01101001 01101110 01100111 00101110 00101110 00101110 00100000 01010111 01100101 01101100 01101100 00100000 01101000 01100101 01110010 01100101 00100000 01101000 01100001 01110110 01100101 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101111 01101011 01101001 01100101 00100001
What specific components are causing the noise?
buying a new graphics card can put more load on the powersupply
Turn down your fan speed?
What is a good temperature for the r7 260x to run?
It's the graphics card. I replaced the old power supply with a cx430w and, before that swap, the noise was the same.
I wouldn't let the temperature go beyond 90*C
If it's running too hot, the fans will increase their RPM - increasing noise. You might be able to solve this by improving the airflow inside of your case. Some things you can do:
  • Clean out your dust filters.
  • Add more intake/exhaust fans.
  • Get proper cable management done to prevent cables from blocking airflow.
  • Maybe the heatsink isn't correctly seated on the GPU, you might need to look into this.
  • Turning on Vsync inside games, as it limits the amount of FPS to make sure your GPU isn't doing unnecessary work.
  • Google other things.
i5 3570K @ 4.3Ghz Turbo (OC) | GIGABYTE G1 GTX 980 Ti | G.Skill 8GB RAM | Samsung 850 EVO 2TB
Thanks! I allready noticed that v-sync helped and I have it enabled on most games. Even on gta 5 I have the v-sync halfed because I'd rather have smooth 30FPS and it lowers the sound just a bit. I will also google some stuff. thanks!
