Razer Kraken VS Kraken Pro
Go to solution Solved by virusal19,
The Kraken and Kraken Pro are both exactly the same in terms of the sound and spec but the Kraken Pro comes with a retractable mic.
My headphone just broke 3 days ago and after some consideration,I have pick this two headphones as my potential replacement.
My question is what is the different between this two other than Kraken Pro have a microphone. If there are no major different between this two in audio quality,i would get Kraken as i do not need a microphone and could save some money.
https://linustechtips.com/topic/45843-razer-kraken-vs-kraken-pro/
yeah i was wondering that to actualy, i did a review on it awhile back here it is if you wanted to see what i thought of it.Love em use them daily for 1-2 hours
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/45843-razer-kraken-vs-kraken-pro/#findComment-603399
Nice review,i am wondering is there a different in sound quality between this two?
https://linustechtips.com/topic/45843-razer-kraken-vs-kraken-pro/#findComment-603417
