Depends. Destilled water + killcoil will prolong maintenance intervalls.
Mayhems makes the best colored coolant.
Really upto you what you're looking for ^^
Frost upon these cigarettes.... lipstick on the window pane...
EK and XSPC are the most "reliable" coolants, after distilled water that is. For looks go for mayhems coolants.
EDIT: ninja'd
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
as said before if its aesthetics your after and you don't care about the very maximum performance, mayhems is very good with a wide range of good colours and dyes that can be mixed for a customer colour.
for maximum performance i believe distilled water is the best but of course it won't have any colour.
any of the major coolant brands, ek, xpsc, koolance, thermochill etc will be good, however i would stay away from uv reactive coolants as they discolour tubing at a rapid rate.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
I agree with this, UV coloured coolant is bad when it comes to staining your lovely nickle plated blocks.
Core - EVGA Classified 3 | i7 980x | 12GB Corsair Dominator GT | Lian Li P80 | Corsair 128 Neutron GTX | 2 x WD 500gb Velociraptor | Asus Xonar Xense | 2 x EVGA 590 | Enermax Platimax 1500
Water Cooling - Alphacool NexXxos 360 Monsta | TFC 360 | Alphacool D5 Vario | Alphacool 250 Tube res | EK Supreme HF Nickle Plexi | 2 x EK Nickle Plexi 590 WB | Aquaero 5 XT
