Search In
  • More options...
Find results that contain...
Find results in...
Nvme support and speed on z97
Go to solution Solved by Tagiau,
you should have enough lanes, just do not plan on running sli in the future with that setup.
Hello,
I got an ASUS z97 PRO GAMER board with m.2 slot and nvme support, will my z97 chipset have the full speed support for the nvme drive or do i need to upgrade to z170 ?
I am really bad in understanding these pci and pci-e lines, i am using too an GTX 970 ASUS Strix OC and the asus usb 3.1 pci card
Thank you  :D
ASUS Z97 PRO GAMER | i7 4790k @ 4.5GHz | GAINWARD GeForce GTX 1080 PHOENIX | Kingston HyperX Savage 1866 2x8GB | Samsung 850 Pro 256GB SSD
Xeon E5 2697 V3, Silverstone TD02, Samsung 64gb 4x16, Asus X99-E WS, PNY Quadro M6000, Intel 750 400gb, 2x Toshiba 4tb, Seagate 8tb, Seasonic 1050xp3, Phanteks Enthoo Pro
i7 5820k, Corsair H110i GTX, 32gb Crucial Ballistix Sport LT, Asus X99 Sabertooth, EVGA Gtx 980ti x2, Intel 750 1.2TB, Seagate Barracuda 4tb, SeaSonic 1050xp3, In Win 805 Black
thank you  :)
