$400-$500 help (switching from consoles to pc)
Im looking to build a Canadian Build for $400-$500
I am going to do some video editing but mostly gaming
I need a Mouse, Keyboard, Monitor and OS
Mouse and keyboard dont have to be mechanical.
Only going to be using 1 monitor and would want Windows 8
I really prefer performance over graphics but if you could get something tht could do equally as good with performance and graphics then that would be good
Looking for Micro ATX Form Factor and
Im looking to get a computer because i game on a laptop and Xbox 360 as well as video edit
I need something more powerful than a xbox 360 for gaming and i need something more powerful to video edit
Comments are welcomed! Thank you
https://linustechtips.com/topic/45715-400-500-help-switching-from-consoles-to-pc/
Gl
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
PCPartPicker part list: http://pcpartpicker.com/p/1rIPf
Price breakdown by merchant: http://pcpartpicker.com/p/1rIPf/by_merchant/
CPU: AMD Athlon II X4 645 3.1GHz Quad-Core Processor  ($74.34 @ SuperBiiz)
Motherboard: MSI 760GM-P23 (FX) Micro ATX AM3+ Motherboard  ($47.24 @ Amazon)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.98 @ Outlet PC)
Video Card: PowerColor Radeon HD 7770 GHz Edition 1GB Video Card  ($89.99 @ NCIX US)
Case: NZXT Source 210 (White) ATX Mid Tower Case  ($39.99 @ Amazon)
Power Supply: Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply  ($39.99 @ Amazon)
Operating System: Microsoft Windows 8 (OEM) (64-bit)  ($88.88 @ Outlet PC)
Total: $505.40
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-08-13 22:35 EDT-0400)
I wouldn't really go any cheaper than this also there isn't any peripherals
Edit: O I forgot wait for 9XXX series.
It's tuff to get a monitor os and parts at that build. I was able to fit the parts and os at around 550. You might wanna spend a little more
http://ca.pcpartpicker.com/p/1rJ1j
The only way to deal with an unfree world is to become so absolutely free that your very existence is an act of rebellion.
Easily done, and much better without a monitor. Just use a TV, and get like a $5 combo of mice and keyboard, if u arent looking for mechanical.
A build I made just a few days ago.
http://pcpartpicker.com/user/codaassasin/saved/27Cc
$440 with no monitor. I can make it better if u want.
The APU is GREAT for most games on the market for medium settings (some high), and the super fast 2400mhz memory really helps, since the graphics relies on system memory and doesnt have its own dedicated fast GDDR5 memory. The decent motherboard supports even up to 2600mhz memory if u want.
Use a Linux os or get Windows 8 or 7 the..."other" way
@Wrench_InTheButt
Folding for LTT since April 2016.
You guys are awesome! I thought no way you can build a decent system for that money and you set up several affordable builds that fit the bill perfectly.  To much brain power going on around here! I'm going to hide in the closet now. :huh:
IF the programs your using take advantage of CUDA, go Nvidia for your GPU. other than that mouse/keyboard are up to you. You can go something well priced and ment for gaming, or a 10$ ebay mouse with cool LEDs but not high grade meant for gaming. same with keyboard. membrane or mechanical.
FX 6300 - MSI 7870 Ghz - M5A97 R2.0 - Team Vulcan 8GB - WD Caviar Blue 1TB - Rosewill HIVE 550w - NZXT Source 210 (white) - Loud Fans
Peripherals - Logitech G105 - Cobra mouse - Acer G236HL - Logitech desktop mic - Logitech LS21 - Audio Technica ATH-M30
Laptop - Acer Aspire V3 - A84500m - 7670m - 15.6" screen (1366x768) - 3.5GB DDR3  - 500GB Scorpio Blue
Get some better peripherals like the Logitech MK120 Mouse + KB combo.
Performance for faster ram really falls off after 1866.
Edits: http://pcpartpicker.com/p/1rPgk
I recommend just to save up a bit more or to get the monitor later if you can use a temporarily use a TV. I use a TV myself since I use my system for media consumption very often anyway. A big display also means I don't have to face battle my screen.
As cheap as you'll find while still being well performing, quality, and upgradable. Just cash in all them rebates ;)
http://pcpartpicker.com/p/1rPpf
Tip: Just use the 8.1 windows for free
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
Faster RAM makes a HUGE difference in APU performance. Source:
  • 2 weeks later...
well if the pc can be $400 and the monitor, keyboard and mouse and OS can be a separate price
http://pcpartpicker.com/p/1wjy2 Is what I made and you can get some cheap keyboard mouse combo if you want. You could also take off the CPU cooler but it's a good idea to have one.  But, if you factor in the yearly subscription of Xbox and PS4 around like 70$ you could spend more on the computer
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
I have a question whats the difference between using an apu instead of a cpu and a gpu
any disadvantages? any pros?
and if you use an apu do u recommend getting a separate graphics card
how do u get windows 8 for free
An APU is a cpu with integrated graphics.
Advantage: Takes up less space, costs less.
Disadvantage: Generally weaker than something like a 7770.
The point of an APU is that you don't need a dedicated gpu.
An APU is a CPU with a GPU on the chip itself. Super awesome idea by amd.
You can use a graphics card with an apu but usually you'll have to disable the on chip graphics unless its a supported amd card for crossfire x.
Use woodenly build but I would change the case to one of the Xion cases that can be found with a psu for about the same price just becaus it looks cleaner.
This is of course unless its a mITX case... In that case haha get it just stick with this build.
