Help with choosing airflow setup for Define r5 case!
Solved by vectorx5000,
ALL THE AIRFLOW!!!!!!!!!!!!! DONT EVEN BOTHER WITH A CASE JUST BUY AN AIRPLANE ENGINE AND BLOW AIR OVER THE RAW COMPONENTS BOLTED TO THE FLOOR!!!!!!
NO BUT SERIUESLY AIRFLOW > LESS AIRFLOW ACORDING TO ME .3
Is it best to blow super hot smoky air at components at hundreds of miles per hour?
xj4ykzyy ·
CDR_Xavier ·
Posted in General Discussion0 -
Awenor89 ·
Posted in Troubleshooting1 -
WiscoMetro ·
Posted in Audio0 -
Mihatzu ·
2
Yeatly ·
Posted in Graphics Cards2 -
9
play_circle_filled
Latest From Linus Tech Tips:
The Stealthiest Tech Upgrade - AMD $5000 Ultimate Tech Upgrade
