Hi guys, I am currently pricing up a new system and am unsure whether to get a A10-6800k or to buy a 4670k with the possibility of expanding in future. I will be using Integrated graphics for a few weeks until I can afford a gtx 760. I already have some cases, PSU and HDD lying around but am unsure of what to purchase. Here are the builds:
Haswell:
CPU: 4670k
Mobo: MSI z87-g45 Gaming
RAM: 1600MHz
Richland:
CPU: A10-6800k
Mobo: Asrock FM2A85X Extreme6
RAM:  1600MHz
I will be adding to them as and when I receive money but would appreciate any recommendations you may have. Thank you for reading.
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/
If it's only a few weeks, go with the 4670K, if not, go with the 6800K.
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599902
its useless basing your system off of intergrated if your getting a 760...the haswell has more than enough intergrated gpu power to play far cry 3 blood dragon at 720....youll be bale to play basically any game at 720 low medium.....some at high with the 4670k....
-Anubikai
| i5-4670k at stock until I do a custom WC loop | H80i | Asus Matrix Platinum 7970 at stock until I do a custom WC loop  | MSI Z87 GD65 | 1TB CAVIAR BLACK | 250gb Blue Scorpio | HX750 80 PLUS GOLD modular | 16GB INTEL EXTREME EDITION PATRIOT 1866MHZ | Coolermaster Storm Enforcer with two Red 20cm fans intake and exhaust |
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599907
go for a 4770k only if you are doing video rendering stuff. or else an i5 4670k is enough!
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599915
TBH, Haswell is kind of overpriced. Plus, it's like comparing apples to oranges in this comparison. Either compare the 8350 vs a non K 4th gen Intel or compare something intel to intel. But to answer your question, I would go with the A10 if you're on a budget, 4670K if you're wanting performance.
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599920
To correct you, it's 4670K, not 4650K
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599928
yep! i know,was writing punishment( i got less marks in math test so........ you know i had to write 50 sums ( i was doing it while i was posting(left hand) so by mistake.............. .
COMING SOON
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599962
are you doing any video editing in this? or just gaming?
COMING SOON
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599963
Haswell:
CPU: 4670k
RAM: 1600MHz
Richland:
CPU: A10-6800k
RAM:  1600MHz
wow those cpu`s are miles apart. possibility of expanding in future ? FM2 platform is dead.and if you won`t oc,you don`t have to buy a K cpu.wow on haswell gpu is flawless  http://www.tomshardware.com/reviews/core-i7-4770k-haswell-performance,3461-7.html
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599967
BTW, how is FM2 dead? The FX line may be dead soon, and will be replaced by APUs, so maybe it isn't a bad idea.
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599979
Just gaming and general usage.
I know they are miles apart but as the FX series don't have an iGPU and I'm going to be without a graphics card for a few weeks it's the only option I have.
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-599988
FM2 is dead. if you want a better performing cpu than that low end athlon x4 what will you do ? nothing. from 5800K to 6800K the performance gain was like what ? 5% on cpu and 10% on gpu ?
also do not buy an apu if you know you will add a gpu later. even if its like 2-3 months
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-600025
Yeah, but the APU will be fine if he decides he may not have a GPU for a few months, but it's up to the OP.
https://linustechtips.com/topic/45582-apu-vs-haswell-base-system/#findComment-600060
