I'm getting a new system this year, it's my first build and I have my parts picked out and I'm getting ready to order them, I'm just making sure everything is compatible with each other and that I won't have any problems, now here's the thing, I'm getting a 770 classified edition which has two 8 pin connectors, and my psu has one pci-e 8 pin and two 6 pin, now my question is could I get away with using one 8 pin and one 6 pin? is there any solution I can get without having to get another psu?
MSI Z87-GD65 - GTX 760 DirectCU II - i5 4670k @4.0GHz - 16GB Corsair Vengeance @1866 MHz
https://linustechtips.com/topic/45512-i-need-help/
Molex to 8pin adapter
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/45512-i-need-help/#findComment-598553
You can get an extension 2x 6pin ----> 8pin. It is very cheap and you can get it in every computer store.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/45512-i-need-help/#findComment-598555
