I just ordered a new case and i know that my 8 Pin connector for the CPU is too short, so i need an extension. The only one i can find is this one  http://www.frys.com/product/6172149?site=sr:SEARCH:MAIN_RSLT_PG  but im not sure if it'll work because it does say that it is a PCI cable. I checked around a little bit more and no other site says PCI, not even the NZXT website. So is this okay to use?
i7-2600K | ASRock Z77 Pro4 | ASUS 980 Ti Hybrid | Kingston 4x 4GB | EVGA Supernova 750 G2 Phantek Enthoo Luxe
Creative X7 Limited | 1TB WD Blue | 2TB WD Green | 256GB Liteon SSD | 240GB Kingston SSD | Corsair H100i
Logitech G502 Proteus Core | Logitech G710+ | LG 34UM65 | LG 27EA31V - B | AKG K7XX Massdrop | Windows 10 Pro 64-bit
https://linustechtips.com/topic/45404-8-pin-power-extension/
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/45404-8-pin-power-extension/#findComment-597082
Doesn't really address my question, but what is the difference between that one and the one i posted? Newegg link for reference since frys isnt really detailed. http://www.newegg.com/Product/Product.aspx?Item=N82E16812170008
https://linustechtips.com/topic/45404-8-pin-power-extension/#findComment-597095
Nothing really.
https://linustechtips.com/topic/45404-8-pin-power-extension/#findComment-597105
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/45404-8-pin-power-extension/#findComment-597110
What the difference between that and the one i posted?
Nothing really.
Okay sweet. I think I'll grab it then once my case arrives. Thanks for responding.
https://linustechtips.com/topic/45404-8-pin-power-extension/#findComment-597129
Besides the fact that for some reason I can't open the link, you said that the title said "PCIe extension" They are wired differently but that shouldn't matter. and extension cable would work, I gave that link because when I clicked on the one another person had posted it said that the item was discontinued.
https://linustechtips.com/topic/45404-8-pin-power-extension/#findComment-597139
I said it was titled as a PCI extension, but for only that website. If you went to Newegg, Amazon, or the NZXT website it is just listed as a motherboard extension cable. Just being a little paranoid about it really. Dont want it somehow damaging my system. But yeah i figured. An extension is an extension,
https://linustechtips.com/topic/45404-8-pin-power-extension/#findComment-597177
Ohh, Sorry, Well aslong as you have your answer now.
https://linustechtips.com/topic/45404-8-pin-power-extension/#findComment-597187
