Hi All,
I am looking at a new GPU solution for myself. The 660 is getting a bit long in the tooth with certain high end games (I bought is as a mid-end solution when the 600 series came out, planning to SLI later...). I can no longer play the games I want with good graphics levels at decent FPS (Above 40).
I have about $500 to spend, considering I can sell my 660 for about $150 on ebay right now. I want the best performance and most "futureproofness" (I hate that word!) for the money. I am willing to do SLI as long as I get it from the get-go because I never did it last time. I would like to play games on high settings above 40 fps for at least a few years. I am also willing to go AMD/ATI if it gives the best bang to the buck to performance. So far I had looked at the 760 4gb SLI and the 770 4gb from Nvidia or the 7950 CFX and the 7970 GE from AMD. Yes, I do want the 4gb version even though I game at 1080p. I play heavily modded Skyrim which eats 2gb for lunch. I have an i5 3570k currently, but I might upgrade before I get rid of this GPU setup if Broadwell is decent.
Thanks,
AM98
https://linustechtips.com/topic/45313-best-~500-gpu-solution/
Definitely wait for amd 9000 series. Get yourself a 9970 when it comes out. Just try to hold out a bit longer with that 660
Nzxt Phantom 410 - I5 4670k stock - 7950 vapor x @ 1000mhz/1250mhz - Msi Z87 G45 - 8gb Corsair Vengeance pro 1600mhz - TX650 - Benq XL2420t - Blackwidow Ultimate 2013 - Deathadder 2013
https://linustechtips.com/topic/45313-best-~500-gpu-solution/#findComment-595678
Ok, when is the 9000 series expected? And at what price point will the 9970 be released at?
Rumored to be announced next month, so out soon.
Starting price most likely 550$ [+/- 50$]
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/45313-best-~500-gpu-solution/#findComment-595694
Ok, is it reported to be better than the 780? Also, where is this rumor coming from? I see it quoted a lot but haven't found an actual article...
Lots of threads in the tech news forum, but I'd expect AMD to release a card better than the 780 or make it sufficiently cheap to make sure it sells
[spoiler=Current Rig:]i5-4670K @ 4.4 Ghz on 1.3v | MSI Z87I | GTX 780 @ 1150 Mhz | 2x8GB ADATA XPG | Samsung 840 250GB SSD | CM V700 PSU | Custom Watercooled in a Caselabs S3
[spoiler=Peripherals:]Mad Catz R.A.T. 7 | Corsair K70 | Sennheiser Urbanite headphones | Corsair Vengeance MM200 | Asus PB278Q + Samsung 22"
https://linustechtips.com/topic/45313-best-~500-gpu-solution/#findComment-597209
I doubt it but I don't actually know.
https://linustechtips.com/topic/45313-best-~500-gpu-solution/#findComment-597443
What I've read it's about 5% faster than a 780, but as mentioned multiple times, it's rumors, we'll know for sure once it's out.
https://linustechtips.com/topic/45313-best-~500-gpu-solution/#findComment-598252
Its basically like an 50 dollar cheaper 780 so if you like Nvidia get a 780 if not get a 9970 Because really 5% of 120 is 126 even then its not like your going to get that in Crysis 3 9970 will be a better deal but its whatever you like.
PRIMARY NVIDIA PC
("I'm a Fanboy of Everything")
| CPU - i5-4670K @ 4.8ghz | CPU Cooler - Antec Kühler H2O 620 | GPU(S) - BIOS MODDED Twin GTX 770 4gb (Gigabyte)-master (Zotac)-slave @ 1337/2000 (8000 Effective) | Mobo - MSI Z87 GD65 Gaming | PSU - Corsair TX850M | Ram - 8gb Gskill RipjawsX @ 1866Mhz | Monitor - Samsung 27" 550 1080p 75Hz | Keyboard - Razer Black-Widow Ultimate 2013 | Storage - 2x 1TB WD-Blacks' | Mouse - AzzA Mouse Would Say "SQUEEKSQUEEK"|
SECONDARY RADEON PC
| CPU - A10-6800K @ 4.6ghz | CPU Cooler - CM Hyper EVO 212 | GPU(S) Twin Radeon 270x 2gb @ 1115/1500 (6000 Effective) | Mobo - MSI FM2-A85XA-G65 | PSU - Logisys 750W | Ram - 8gb @ 1600mhz | Moniter - Acer 24'' 1080p 60Hz
https://linustechtips.com/topic/45313-best-~500-gpu-solution/#findComment-598324
