Search In
  • More options...
Find results that contain...
Find results in...
Best/strongest, most stable Lithium-ion battery?
I need to buy a new high-capacity 1880 mAh lithium-ion battery for my mp3 player.
Who makes the best batteries?
I'm not concerned with  price, just want to get the strongest, longest lasting one available.
Chances are Li-ion batteries are proprietary, so there is not much choice anyway. Buy original batteries?
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
well.. what shape of battery are you looking for?
AAA?
9 volt?
Umm. The 1880mAh value is the indicator for how long the battery will last on one charge. If you're set on that, what else are you looking for?
Also we, really need the voltage and form factor to be able to comment.
I'm sorry it's going in a Sony NW-ZX2...I'm looking for a manufacturer that makes premium batteries.
AAA?
9 volt?
AAA?
9 volt?
It's for the Sony NW-ZX2. I can't get the Sony battery so an after market one is what I'm after.
If the aftermarket battery is the same size but a drastically different size, its fake.
I am a happy wuffy
