How much RAM does Premiere pro normally use?
Go to solution Solved by Theo,
If you have more ram itll use more ram, premiere pro is generally better than vegas imo
I figure this is a simple answer and that the answer will be yes, but does premiere pro usually use close to 10GB of RAM when rendering. I've just switched from Vegas which was only using 4 or so and was wondering if it's normal for premiere pro to use 10gb. It's not much of a big deal, I still have 18GB free. This is a curiosity thing
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/44544-how-much-ram-does-premiere-pro-normally-use/
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
In terms of RAM usage it's not... For me at least. I only switched to Premiere because the latest version of Vegas is too buggy and only renders my video half the time. And you're right about using more RAM. It's up to 12GB
Just because it uses more ram doesnt mean its worse, it sees you have the resources and its using them to probably render the video faster than what vegas would do. Plus i think in the settings you can cap how much ram it can use
The RAM usage doesn't bother me. I genuinely prefer to edit using Vegas. Just a personal preference, but that might change when I get better with Premiere
Yeah same, but its cause im used to Vegas and ive my render settings all set in, but Premiere has more things and can render faster with equal quality settings ( i think )
Vegas is SO user friendly it's not even funny :P I use after effects quite well and I still use vegas for quick things because it just feels so smooth!
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
