My current seagate barracuda is particularly filled up.
So ,i was thinking on buying an external HDD for mainly gaming and storage.
Need help.
Thanks rutwik.
THE LITTLE DEVIL : i5 4690k on NOCTUA NHD15
Asus z97 sabertooth mark 2
WD black 1TB & WD Green 2TB HDD, Samsung 840 Evo 240gb & Hyperx 240gb SSD
RAM- Corsair vengence 16gb and hyperx fury 8gb
PSU-Seasonic sII 620 wtt power supply
PErPHERaLS: Logitech g403 mouse, Redgear cherry MX brown switches, Logitech gamepad f310,Cosmic byte XXL RGB mousepad
Audio: SennheiserHD 558 and antlion mod mic
PHOnE: Realme 3 pro
https://linustechtips.com/topic/44541-need-external-hard-drive-for-gaming-purposes/
Welcome to the forums!
Well you could but itll be slow and stuff, specially if its USB2, if its USB3 itll be better but still wont compete with SATA2/3 for the random writes/reads i think.
You should better; either remove things and free up space, or just get a new internal hdd
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
Why not add an internal harddrive? Cheaper and faster ;)
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - DellAlienware AW3423DWF 34" -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Northern Lights Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 7x14TB Ultrastar RAID Z2 - - 45 HomeLab HL15 15 Drive 4U - - Corsair RM650i - - LSI 9305-16i HBA - - TreuNAS + many other VM’s
iPhone 14 Pro - MacBook Air M3
USB 3 is 5gigabits/sec and Sata 3 is 6 gigabytes per second. A HDD wont saturated any of those, at all.
Yes for large files itll be fine, but random reads/writes will be slower on USB3 cause of added latency
If your just putting games on it, the worst that can happen is you have to wait like 5 extra seconds on the loading screens.
Get an internal drive it's faster. Though don't worry about the HDD saturating the bandwidth on USB 3. Hard drives aren't that fast.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
Yes thats generally true, but if the game is like Fallout New Vegas and you have a big texture pack you ll get terrible stuttering, so if the game loads textures or other things while youre playing, you ll get stuttering with usb3
I've never had that problem and I've played Crysis 3 @ 1440p with 16xAA using 4xMSAA. While running it off a external HDD.
What do you mean for gaming? Because I would never run a game of an external if it could at all be avoided.
I need this since i am going to be pursuing my course in a hostel therefore i need one.
Thanks.
Doesnt external HDDs with 7200 rpm be better if needed to use.I dont know about any of the HDDs running 7200 rpm need help
PHOnE: Realme 3 pro
Thanks.
buy a USB 3.0 (USB SuperSpeed or USB SS) Hard Drive with a decent brand name like seagate or WD(Western Digital) and it will be fine for your basic gaming purposes.
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
Can u give me some suggestions pls
PHOnE: Realme 3 pro
So internal or external?
You always have the option of buying a bare drive or your choice and buying a external enclosure of your choice and putting the two together.
I would not recommend running games from an external hard drive, an SSD is ideal but you could use something like a western digital black drive internally for a compromise in price.
Accidentally pooped my pants in the elevator.
I'm taking this shit to a whole new level.
I have already tried explaoning that and suggested that. So idk.
External for preety much storage then have to transfer setups to external and free up internal .
Any suggestions for better external drives ??
PHOnE: Realme 3 pro
so you want the external drive to be powered of the laptop or can it have a AC adapter?
also are you willing to build your own? the reason I bring this up is very few prebuilt drives have 7200rpm drives
I want it to be powered by laptop perferably compactible with 2.0 since i maybe giving game setups to friends.
I didnt know 7200 rpm external HDD without power adaptor are availiable so surely need multiple suggestions for that.
I cant build my own as in india its pretty much costly than getting one plus no things are availiable i have checked into that.
PHOnE: Realme 3 pro
then your not going to be able to get a 7200rpm external if you can build one. i would then just go out and buy anything by Western Digital or Seagate as their all the same for the most part.
PHOnE: Realme 3 pro
PHOnE: Realme 3 pro
