Symantec Blocks mslldp.sys
MoBo
So after a few other Topics that i can't connect to black ops 3 beta or that i can't play advanced warfare online, i am starting to get a message from symantec that the traffic from mslldp.sys was successfully blocked. So how do i stop symantec from doing that (cuz i think it has to do with the mslldp.sys file from letting me play games)
Black ops 3 beta is over.
yea but still i can't play advanced warfare online
Remove the AV. Norton sucks and slows down your PC a lot. Way over protective too.
blackshades on
Norton.....theres your problem. Uninstall and then never reinstall it.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
BTW its not norton
Its Symantec Endpoint Protection
Simple answer: REMOVE THE FUCKING VIRUS/ANTIVIRUS. They are usually more annoying than the viruses themselves. If you really need an antivirus, use Malwarebytes.
My native language is C++
