Hi i'm in the middle of a water cooling loop which has the current specs :
Corsair Obsidian 800D
Samsung Internal Combo Blue ray Drive
Corsair Dominator Platinum 16GB (4*4) RAM
Water cooled VTX3D HD 7970 GHz X-Edition Gpu's (2 In crossfire)
Noctua Nf-F12 (2)
Silent Cougar Vortex 120mm Fan
Seagate Barracuda 2TB Hardrive
Corsair AX1200 with Custom Braided red leads
Asus Maximus Extreme V
Intel 3rd generation Core I7-3770k CPU
Total
Water cooling Gear
Swiftech MCP655 Pump
XSPC RX360 Radiator + Noctua NF-F12's (top mounted)
Hardware Labs Black Ice 120mm Radiator +Noctua NF-F12's (rear mounted)
Phobya G-Changer 140mm Radiator + Noctua NF-A14
EK full cover water block (EK-FC7970 CSQ + Corresponding backplates)
EK-FC Bridge DUAL Serial 3-Slot CSQ
EK-RES X3 400 Reservoir
Primochill PrimoFlex Advanced LRT 7/16" ID - 5/8" OD (11-16mm) : Bloodshed Red
I plan to mod the case so that It can fit a 240 rad at the bottom.  As you can see i'm using primoflex tubing (red) and clear distilled water with a kill coil and some pm nuke, I really want to be able to see the reservoir, but it's going to look odd with my colour scheme (red and black), because im using clear fluid, anyone got any ideas to get around that?
https://linustechtips.com/topic/44487-tubing-coolant-colour-etc/
Try getting clear tubing and use some nice red coolant, I think it looks better like that anyway
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/44487-tubing-coolant-colour-etc/#findComment-583392
1. top mounted as in external or outside the case or fans in pull? using a focus-flow
fan after the radiator is non-effective.. the focus-flow is in push mode.
2. using a BIX 120 (20fpi) and low fpi XSPC and Phobya really isn't helping as the
mix of air-pressure/fan speed to cooling performance would be negated.
3. instead of three rads, just use a one simple 240 (XSPC or Alphacool fpi) and
sell the 120/140 single fan rads. more leakage points and nightmare on tube routing.
4. kill coil or biocide agent, not both..
5. sell the ek and use red tinted bitspower reservoir. LINKY
airdeano
https://linustechtips.com/topic/44487-tubing-coolant-colour-etc/#findComment-583557
airdeano
Sorry my bad forgot to say will be using the nf-f12's in the internally pushing the air through, and some aeroocool shark fins to pull the air out, do you have any pull fan advise?
Your probably right, I'l buy a 240 rad for the bottom, do I have to be careful about the height of the 240 rad?
https://linustechtips.com/topic/44487-tubing-coolant-colour-etc/#findComment-583973
.. forgot to say will be using the nf-f12's in the internally pushing the air through, and some aeroocool shark fins to pull the air out, do you have any pull fan advise?
if using the shark fins for lighting effects, ok. but understand they may also be a
hindrance to the NF-F12s to exhaust the air.
as for width on rad, if you are mounting horizontally, any 120 rad will work. if mounting vertically,
the narrowest are the XSPC or Phobya/EK @ 120.1mm the Alphacool are a skosch wider.
the horizontally mount of rad a simple 60 thick with a fan set will be fine.
airdeano
https://linustechtips.com/topic/44487-tubing-coolant-colour-etc/#findComment-585900
