My 4770k is overclocked to 4.4Ghz and I am getting temps in the mid 80's when running prime95, i am using an h100i to cool it. is this abnormally high?
 i7-4770K, Corsair H100i, Asus Maximus VI Hero, Corsair Vengeance Pro 16GB, Samsung 840 120GB, 2xSeagate Barracuda 1TB, EVGA GeForce GTX 780 ACX Cooler, NZXT Phantom 820, Corsair Professional 750W 80 PLUS Gold, 2xASUS VH238H Build Log- http://bit.ly/1bWZKu6
Thats fine, what is your ambient temp and what voltage did you set in for that oc?
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
Voltage is 1.2 W/ Adaptive, Temp @ idle is 33 Degrees
Haswell is notorious for having cheap TIM between the die and the IHS. You cannot send for RMA as your CPU isn't actually faulty, however you could either delid or lap your CPU which would void you warranty. Another option is to lower the voltage on your CPU in order to reduce the amount of heat produced. As long as your keep your CPU below 1.5V and 90C you should be fine.
Sam,
Intel Response Squad member
http://bit.ly/RallySquad
Sam,
But is it bad to run it this hot? Or is this ok?
this actually sounds like on of the better 4770Ks
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
Updated my post.
Dont worry temps are fine, plus in games you ll never really pass 70ish C so no worries
DUDE you are lucky trust me I tried to overclock to 4.5Ghz on 1.255 and my CPU wasn't stable but booted. Being able to get 4.4Ghz on 1.2 IS freaking amazing.
1) Don't use prime95 it's not haswell certified try Auda64 or Intel's Overclocking Software
2) You can probably get to 4.5Ghz since you only need like 1.2V for 4.4 and your temps will be cooler because prime95 is an unrealistic load, try Intel's software
I have the same hardware as you I have to run at stock, you got a good CPU.
2) You can probably get to 4.5Ghz since you only need like 1.2V for 4.4 and your temps will be cooler because prime95 is a unrealistic load try Intel's software
1.25V and 4.5 didn't boot...
You got a decent chip, congrats!
Mine takes 1.275v for 4.4Ghz to be stable on air.
9900K  / Noctua NH-D15S / Z390 Aorus Master / 32GB DDR4 Vengeance Pro 3200Mhz / eVGA 2080 Ti Black Ed / Morpheus II Core / Meshify C / LG 27UK650-W / PS4 Pro / XBox One X
You still got a great CPU, my 4770K is complete shit compared to yours. Under Aida64 my CPU goes to 80C+ running @stock with a h100i.
I think you have got a bad mount...
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
I remounted the h100i I'm gettling like 70C-75C under load and remain 30C at idle which is good I guess. What V are you using at 4.7?
I have to edit my sig  again but I'm running 4.6 @ 1.38v (haven't had time to try and bring volts back down)
But my load temps are 20ish at idle and 50-60 at load with a custom loop..
LUCKY...
Is Aida64 safe to run with adaptive voltage?
LUCKY...
It is REALLY nice, best parts purchase I have made apart from an SSD :D
It can still draw too much power just like Prime although from the testing I have done its very minimal.
With My Cpu under an Aida load my temps are only in the mid 50's...
