I am thinking of getting a new headset and a dedicated sound card. My budget is around $100.
I am looking at the SteelSeries Siberia V2, Plantronics GameCom 780,Corsair Vengeance 1300, or the Razer Kraken PRO. Then I am looking for the Asus XONAR DG for the sound card.
Which one would you pick out of these or would you have something else to suggest? I have a motherboard with realtek alc892 on board audio currently.
Thanks for the help.
https://linustechtips.com/topic/44361-gaming-headset-and-sound-card/
Friend has siberia's and there awesome . Corsair vengence 1300 also awesome i have the razer krakens and there also awesome.. so yeah any thing.
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
I really like the 780s they're awesome
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
Better headphones and an antlion modmic will give you better sound quality from the mic and out of the cans. Headphones like these http://www.headphone.com/headphones/superlux-hd681.php
Feel free to message me if you want to chat!
you're better off with headphones and a mic over just about any headset.
ad700 and HD558's are my typical recommendation.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
Would you say that a usb headset is worse than a normal 3.5 jack headset?
Would also like to know this!
i5 4670k @ 4.6Ghz | Corsair H100i | Corsair Vengeance Pro 8GB (2x4) 2133MHz | Gigabyte GA-Z87x-UD3H | Silverstrone 850W | Fractal Define R4 | Samsung 840 250GB | Seagate 1TB 7200rpm HDD | 2x Gigabyte Windforce Gtx 780s
I have the siberia v2, however i get headaches when i wear them for a longer period of time, but i think that is just me since i have really large ears.
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
Real headphones > gaming headsets
Enjoy those tacos now, for in 1000 years they will be illegal... eh Ha Ha Ha! I think we all know why.
༼ つ ◕_◕ ༽つ Give tacos ༼ つ ◕_◕ ༽つ Poker 2 KB Review
A USB headset will most likely have a it's own soundcard built in somewhere, most likely inline on the cable somewhere. So it would need to be compared with either a similarly priced headset using a 3.5mm jack + an internal or external soundcard, or a headphone + mic of the same price as the USB headset but using the onboard audio of the device you intend to use it with.
Generally these built in soundcards are there in theory to give the user something better (however slight that may be) than onboard audio and sometimes to utilise virtual surround sound and other processing.
Basically one is not better than the other, it depends on the person's situation and budget.
Headset
Not likely - absolutely. :P
I'd recommend spending all your budget on the headphones or - eek - headset rather than including a soundcard.
Well, on the bright side, you don't have to worry that your amp isn't optimal, and you wouldn't need to buy a soundcard for it.
On the downside, EVERYTHING is on one gadget and if it breaks you're out the whole kit and caboodle.
Too much bundling in my opinion.  Also the quality of each component tends to be sub-par for the price.
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
go for one good soundcard or one good headphone.
i came from a Megalodon(trash product), now i'm using the Sony XBA-40's to game and for movies/music. saving for a DT990 and a Fiio E10+Zalman mic lol
can't go wrong lol.
