Budget : Around £950, UK.
Aim: Will be used for general use and gaming. Games I plan to play range from Fallout, Far Cry 3, GTA, Watch Dogs, and indies but if it can play the AAA titles, Indies are usually fine.
Monitors: Single 1080p monitor, must be included in budget.
Peripherals : Own a mouse, but require a keyboard. Am leaving out of the budget, as will pick up a cheap one for a month tops, before purchasing a mechanical keyboard.
Why? : Currently on a laptop, want a desktop and the added benefits that follow having one.
Current Proposed Build.
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  (£179.99 @ Aria PC)
CPU Cooler:  Noctua NH-D14 65.0 CFM CPU Cooler  (£62.39 @ Ebuyer)
Motherboard:  Gigabyte GA-Z87X-D3H ATX LGA1150 Motherboard  (£118.15 @ Amazon UK)
Memory:  G.Skill Value 8GB (2 x 4GB) DDR3-1600 Memory  (£51.60 @ Amazon UK)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£45.59 @ Aria PC)
Monitor:  LG IPS234V-PN.AEK 23.4" Monitor  (£118.00 @ Amazon UK)
Other: OCZ OCZ-ZT750W-UK 750W modular PSU (£79.99)
Total: £726.70
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-08-09 18:00 BST+0100)
I'm undecided between 760/7950, which is why It lacks a GPU. Will most likely use the integrated for the time being and look into the 9000 series next month.
Also giving myself a little leeway and going 750W PSU to allow for SLI/CF at a later date.
Lacks an SSD as it will be added at a later date, but my birthday is coming up so may actually just wait and purchase it all at the same time to prevent hassle.
Was mainly looking for any changes you all may have, or ideas for what sort of colour scheme I could use with the Mobo etc.
Thanks for reading
CPU: 6700k GPU: Zotac RTX 2070 S RAM: 16GB 3200MHz  SSD: 2x1TB M.2  Case: DAN Case A4
https://linustechtips.com/topic/44335-~%C2%A3950-build-advice/
I'd rather get an FX 8150 or 8350 and a 770 / 7970. Also you could probably get an R4.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/44335-~%C2%A3950-build-advice/#findComment-581296
The budget for the GPU isn't set yet, after the 9000 series announment, will wait and look at my options. If the US 7970 price drops come over here, I'll get one straight away.
As for the R4, I did look into it, but I actually prefer the look of the Arc.
I had the same budget as you and got the 7950 and i am perfectly happy with it
Also got the arc mid r2 and it's a very good case
I know if I got a 7950 I would be completely fine with it, but I'd also be so annoyed if a month later a better card came out at a lower price.
And good to hear about the case :)
https://linustechtips.com/topic/44335-~%C2%A3950-build-advice/#findComment-581329
Left the GPU out since you are going to wait for the 9000 series.. 8320 is more than enough for gaming etc.
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  (£113.99 @ Aria PC)
Motherboard:  Asus M5A97 R2.0 ATX AM3+ Motherboard  (£68.97 @ Amazon UK)
Memory:  Patriot Viper Xtreme 8GB (2 x 4GB) DDR3-1866 Memory  (£46.25 @ Amazon UK)
Storage:  Samsung 840 Series 120GB 2.5" Solid State Disk  (£71.99 @ Aria PC)
Monitor:  BenQ GW2450HM 24.0" Monitor  (£155.46 @ Dabs)
Total: £746.47
(Generated by PCPartPicker 2013-08-09 18:49 BST+0100)
1000 Watt is overkill but we don't know the wattage the new 9000 series are going to pull and the PSU is 80PLUS Platinum and it is like 5-15 Pounds more expensive than a 800+ Gold/Platinum PSU so... better overkill than underkill IMO.  For the monitor i chose i used this review: http://nl.hardware.info/reviews/3112/20/22-23--a-24-inch-monitoren-review-beeldschermenbal-conclusie
Goodluck with the system!
Interested in Business and Technology
https://linustechtips.com/topic/44335-~%C2%A3950-build-advice/#findComment-581405
Looks like a sweet pc. Good luck with your build, hope to see it in the build log section soon!
CPU: AMD FX 8350 @4.7 Ghz  Cooler: Cooler master seidon 120m GPU: EVGA Gtx 660 SC Ram: Corsair 8Gb  Storage: 128 Smasung 840 ssd and 1 Tb wd blue. Case: Corsair Air 540
https://linustechtips.com/topic/44335-~%C2%A3950-build-advice/#findComment-583250
Edits/suggestions: http://uk.pcpartpicker.com/p/1qjt9
Crossfire ready.
You have enough left for a good mech keyboard.
https://linustechtips.com/topic/44335-~%C2%A3950-build-advice/#findComment-583792
