Best watercooler for maximum silence and performance
I am a very big silence freak, and i need the absolutely most quiet all in one liquid cooler i can get to hold a 4770k on 4.8Ghz with a max temp of 80 degrees in a 25 degree room. My room is unfortunately very hot during the summer. I dont care witch brand. If i have gotten this correctly, is it possible that the most quiet and most performance solution is the swiftech h220 with reduced pump and fan speed according to linus`s videos of it?? Im confused :S Thanks beforehand! :D
HTPC: Approx 449$ USD total (Built by used hardware) = Chassis: Fractal Design Node 605 CPU: Intel Core i7 2600 GPU: Asus GTX 960 Strix 2GB RAM: 2x4 GB Kingston Value DDR3 LP MOBO: Gigabyte GA-Z68AP-D3 rev. 1.0 SSD: Samsung 850 Evo 250GB PSU: LC Power 600 Watt LC6600GP2 CPU Cooler: Stock (For now)
Main Rig: (In Planning/Saving up)
best watercooler would be custom! ;)
otherwise get a h220 with a set of noctua fans.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Yes the most quiet AIO is the swiftech H220. It is the #2 performing AIO, but #1 has to be 17db louder. If you have a case that can fit it I would try to get a swiftech H320, since it has more rad space the fans can be quieter while achieving the same performance.
Build your own loop with lots of rads and fans that hardly spin! That's how you achieve true silence.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
I can`t believe how fast i got response on this thread!!! Love you guys. Forgot to mention how much i was going to spent the max, and that is MAX 200 bucks, isn`t that what you have to pay for the h220 with some nf-f12??? I got a fractal design define r4. so the h320 will not fit snifff  :(
Again THANKS A LOT FOR THE LIGHTNING RESPONSE! :D
And then if your like me you have a custom loop and a fixed speed pump thats sounds like a plane taking off constantly...
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
But the price is a bit high for a custom loop right? :S
For AIO, Kraken x60, H220, or H320(Noctua fans on all).
