legacy to UEFI Issue
Solved by kameshss,
Download and run Rufus software.
Insert your USB,
Select your USB from "Device" in the software menu,
Select GPT Partition scheme for UEFI computer,
Select the Windows ISO image in the little CD icon,
And then start the process. Your USB drive will be formatted and copied with Windows Installation files in it.
Then try to boot.
It should work.
Don't missout to select GPT Partition scheme for UEFI computer. It is important.
