When will the 4GB version of the ASUS GTX 770 be released, i have been waiting to upgrade and plan to buy two for SLI on my triple 1080p setup. All other major vendors seem to have released their high memory rendition, and i can't find any news relating ASUS' card.
CPU: i7 4770k @ 4.8Ghz, MoBoROG Maximus VI Formula, Graphics Cards: Dual MSI 4GB@8.5GHz Nvidia GTX 770@1.3GHz , Memory16GB Kingston HyperX @2.4Ghz Boot Drive: Samsung 840 Pro 256GB, Storage: RAID 0: Seagate Barracuta x2 4TB, PSU: Corsair GS 800, Cooler: Corsair H100i, Case: Antec P280 Peripherals: Triple ASUS VH238H 1080p monitors (5760x1080p), Razer Mamba, Razer Black Widow Ultimate, Razer Orbweaver, Steelseries H Wireless
Laptop: ASUS G750JW: CPUQuad-Core i7 4th Gen @3.4Ghz, Memory12GB memory, Storage: 1.5TB Hard Drive (1TB + 500GB), GPU: GTX 765m 2GB-GDDR5
https://linustechtips.com/topic/42274-when-will-asus-release-their-4gb-770/
I hear that the 4GB 770 is not worth it. From what i understand each 1gb of VRAM should have 128 bit memory bus. The 770 4GB has a 256 bit memory bus which means it would be best with 2gb. I know there is more to it than that so i'll let others add on to what i have said
i7 4790k | Asus Z97 M-Plus | 16GB Mushkin 1600mhz | Sapphire R9 390X | Samsung 830 128GB SSD | 1TB WD Blue | Corsair HX750i | Corsair Carbide 330r Blackout Edition
I don't think anyone knows but i'm guessing soon. Impact comes out in like a week and a bit JJ said so maybe around then?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
Learned from previous post ;P And Yes. It's not worth it. If you were to go for it, might as well just get a 780
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
hmmm, i thought the 780s were going to be 5gb on the high memory models
Titan 6GB, 780 3GB, 770 4GB, 770 2GB, 760 4GB, 760 2GB,
Titan and 780 got 384bit memory bus, while 770&760 got 256bit.
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
they cant release a high memory model of the 780 since nvidia wont allow manufacturers to do it probably because it would affect sales of the titan
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
yeah that's not factual at all there's no benchmarks or anything that proves it. 4gb is defiantly worth it in skyrim with crazy enb
PRIMARY NVIDIA PC
("I'm a Fanboy of Everything")
| CPU - i5-4670K @ 4.8ghz | CPU Cooler - Antec Kühler H2O 620 | GPU(S) - BIOS MODDED Twin GTX 770 4gb (Gigabyte)-master (Zotac)-slave @ 1337/2000 (8000 Effective) | Mobo - MSI Z87 GD65 Gaming | PSU - Corsair TX850M | Ram - 8gb Gskill RipjawsX @ 1866Mhz | Monitor - Samsung 27" 550 1080p 75Hz | Keyboard - Razer Black-Widow Ultimate 2013 | Storage - 2x 1TB WD-Blacks' | Mouse - AzzA Mouse Would Say "SQUEEKSQUEEK"|
SECONDARY RADEON PC
| CPU - A10-6800K @ 4.6ghz | CPU Cooler - CM Hyper EVO 212 | GPU(S) Twin Radeon 270x 2gb @ 1115/1500 (6000 Effective) | Mobo - MSI FM2-A85XA-G65 | PSU - Logisys 750W | Ram - 8gb @ 1600mhz | Moniter - Acer 24'' 1080p 60Hz
