Should I get a 20cm or 30cm LED for the 350D?
By
Worth
in Power Supplies
in Power Supplies
Solved by TheDigitalRealm,
Depends where they're going bud. If your looking at placements on the top inside and bottom inside of your case, then either should be fine. I'd look at the case's measurements just to be sure.
Really though, it depends on the intensity of the lighting your going for.
Rotapple1 ·
Posted in Networking1 -
LudicrouslyLiam ·
Posted in Displays0 -
Infernic ·
Posted in Graphics Cards14 -
2
Veronica12 ·
Posted in Troubleshooting8 -
1
play_circle_filled
Latest From ShortCircuit:
This Laptop IS Available in America (for now) - Framework Laptop 13" Ryzen AI 9 DIY
