Your RAM is likely not functioning properly.
https://linustechtips.com/topic/42154-asus-mobo-dram-led-is-red/#findComment-548402
Hit the memOK button and let it cycle through RAM settings.  If it still doesn't boot, try moving around the memory to different slots, and try booting with one module at a time.  You likely have a bad memory module.
https://linustechtips.com/topic/42154-asus-mobo-dram-led-is-red/#findComment-548408
Hello, i just got myself a new gpu and cpu cooler, after booting my pc up for the first time i see a red dram led lights up and after a minute the pc restarts, repeat, does anyone know how to fix this?
Go into BIOS and see what is wrong. Hit the direct key button on your mobo and it should take you to the bios.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/42154-asus-mobo-dram-led-is-red/#findComment-548516
