must have space for a duel 120mm rad for future 2 front 120mm intakes 1 120/140mm exhaust + bottom mounted power supply also with cable management holes/gromits i don't mind a triple rad spot or any extra cooling also drive bays will not be used really so removable ones would be good my budget is not very big about 70> £  only Thanks
Owner Of The Crappy .gifs
https://linustechtips.com/topic/42109-need-a-case-for-my-build-details-below/
Corsair Obsidian 550D, if it is available in the UK.
Thanks,
terrytek
